Marty/Svarc, could either of you please comment on following: I was told by one of the installers the Sungrow SG5K-D inverter can be fitted with a battery without much extra expense; is this correct? I was under the impression if I want to add battery later on it would be cheaper to install the hybrid Sungrow instead. Your comments would be greatly appreciated.
Hi @Paulaching
You can quite easily add a battery with a standard inverter, but it does limit your options a bti. You can get more info here:
Let us know if you still have questions after reading that.
Many thanks Marty; you’ve changed my mind getting the hybrids.
| Marty Pro
May 13 |
Hi @Paulaching
Home solar battery systems - Comparison and costs — Clean Energy Reviews
An introduction to the many home solar battery options available on the market along with detailed reviews, comparisons and information about the most popular solar battery systems.
