Solar Panel Installers Melbourne area
Hi There,
I’m looking at installing a 5kw solar panel setup at home.
I’ve done some research it and looks like LG and Sunpower are the best panels on the market with a Fronius Inverter.
Can you provide Solar Installers in Melbourne that supply and fit the above brands?
regards
Phillip
Hi @Philski_Phil
Yeah, good choices, you can’t go wrong with those brands. Most reputable installers should be able to get LG and Fronius for you (Sunpower can be a little harder).
We’ve got a few Melbourne installers listed on our website:
https://www.cleanenergyreviews.info/solar-power-installers-melbourne-victoria
There was also someone in this topic below getting a Fronius and LG install in Melbourne. It might be worth checking with @Jelley how the install went, if it’s happened yet.
Hi @Philski_Phil and
Marty,
I haven’t gone ahead with the install yet, will let you know when/if I do.
We use froniis exclusively but the LG for a slight increase in efficiency is twice the cost of other panels such as Rec which is what we use
