Hi @le3bl
A lot of the quotes you see here are for Australian properties. Our federal rebates are added up front which is part of the reason the quotes are less, but also for reasons I’m not real clear on, residential solar is way cheaper in Australia.
The products you are quoted are top quality, and the system is large, but with that in mind the quote still seems incredibly high.
In Australia we generally recommend using local providers. Utah is an awful long way from Indiana, do you not have any local providers near you? We always recommend getting at least 2-3 quotes so you can compare.
I would question whether you need a 10kW system also. How much electricity do you use on a daily or monthly basis (should be in kWh on your bill. Lastly, what’s you main reason for going solar? If it’s financial, I struggle to see how you would get a good return on investment at the price you’ve been quoted.
Hope that helps
Indianapolis Solar Installers
Jefferson Electric seems to be one of the few local Indianapolis companies doing solar power, whilst GRNE services Indiana and another three states and gets high reviews.
Jefferson Electric | Indianapolis, Indiana
GRNE Solar | Indianapolis, Indiana
Electric Plus, Inc. | Avon, Indiana
