Hi everyone,
I’m planning to install a solar panel system for my small home (around 1,200 sq. ft.), and I could really use some advice from those with experience. I’ve done some initial research but feel a bit overwhelmed by the options available.
Here’s my situation:
- Energy Usage: Monthly consumption averages around 600 kWh
- Budget: Mid-range, willing to invest in quality but not looking for the most premium option
- Roof Space: Limited but enough for a reasonable setup
A few questions I’d love some input on:
- Panel Recommendations: Are there any brands that stand out for durability, efficiency, and warranty support? I’ve been looking into REC, Q Cells, and SunPower—any thoughts?
- Inverter Choice: String inverter vs. microinverters—what’s best for a system my size? I’ve heard good things about Enphase and Fronius, but I’m unsure which would be best.
- Battery Storage: I’m considering adding a battery in the future. Should I plan for this now, and which systems offer the best compatibility?
- Installation Considerations: Any common mistakes to avoid or things I should make sure my installer does correctly?
- Real-World Performance: If anyone has a similar setup, how has it worked for you? Any unexpected issues?
I also checked this: https://forum.cleanenergyreviews.info/t/solar-panel-installers-melbourne-area/
I appreciate any advice or recommendations. Thanks in advance!
