May you can help me understand this a bit better?
Assume you mean Isc (not cs) from the datasheet? The 6kW model - I would like to order - has 17A per mpp tracker.
I would start with a first string of 8 modules on one tracker. Then after some structural adaptions add a second string next year.
If the 8 modules are mounted in series, it would look like this.
All Volt, Ampere and Watt values - as best as I understand - should fit into what the inverter can deal with. (Slightly above max mppt v range in very cold weather conditions)
But it seems not possible and useful to think about a 2parallel x 4 modules connected. This would still fit into min startup and mppt voltage thresholds, but the modules then would deliver 13.6 + 13.6 = 27A which is more than the supported 17 for the 6kW model.
Just wonder what the benefits for a parallel arrangement would be? Lower voltage afaik increases the resistance effect of the cables. And adding more than 4 modules wouldn’t make sense as it exceeds the max Watt the inverter can handle .
Next I’m not sure how to expect and understand the string power under different temperature conditions: the 6kW model has 7800W max DC input power.
At min temperatures the string would have ~440V
The module Isc of 13.6A would need to go down if voltage goes up, because the generated power will remain ~ the same at same sunlight power, right?
I see something in the module datasheet, but this seems not enough temperature/voltage effect to me, not?
Last but not least the watt/m² values from the module specs, paired with what watt/m² I can expect at my location over the year
So in cold months with highest string voltages, the max power will be way lower than what the inverter could handle.
Would it make sense, or be possible at all to add (connect) additional modules during cold months? If in series it would clearly exceed the max 500v per string.
But if 2 parallel “substrings” each with 8 modules would have 2x 13.6A this would not fit into the inverter specs.
On the other side, if voltage is such high, the Amperes must be way lower then, right?
Eg at 300w/m² and 21% efficiency this would be max 125W on this 2x1m module. And 1000W on a 8 modules in series string. Would it be 2000w then with 2 series of 8 in parallel?
Assuming a 400V this would mean 2.5A from the single 8 series and 5A from the dual 8 series string.
Sorry for so many theoretical numbers, assumptions and questions.
