Solar panels suitable for Ghana West Africa
Hi @Jaytay50
Any solar panels are suitable to use in Ghana. The system depends on your needs. Are you connected to the electricity grid or not? Is the grid reliable?
@Alloy might be able to help you, he is in Ghana also.
Regards
Build one of these Dual Axis-solar Tracker, where one 500W panels will generate 5kWh/p energy per Day.
https://www.micropowergrids.com.au/_Solar_Generation/_DAT-1_Solar-Tracking-Unit.html
Purchasing a Battery is smarter long term investment than purchasing an oversized Solar Array.
Good luck.
