Hello friends any one has the experience to connect two solar charge controller to one battery bank for more current e.g each controller has 600watt pv and produce 25amp so in parallel it would be 50amp . My controller only support 30amp so that’s why thinking about to buy another device and panels for more backup
It’s very common to use 2 or more charge controllers on one battery. Just make sure all the controllers are programmed with the same charge voltage settings. You should always use the same size battery cable as well.
Some controllers, like Victron MPPTs, can communicate with each other.
Right, I also thought about two batteries in series but it will double the output and will damage 12v fans and lights , 2 batteries in parallel would be ok. But will both be charge and discharge equally?
