Hi Guys,
My off-grid system has been running well for the past 2 months so I am now looking into protecting it from lightning induced surges.
The 25 rooftop panels are configured into 3 strings (8-8-9 panel) with each string mounted on 3 parallel line-ups of aluminum rails. All of the mounting clamps are also aluminum.
I have a question on how to properly ground the panels and would appreciate your expert opinion:
I read that the anodized frames of solar panels and mounting rails have an oxide layer that is not electrically conductive. For this reason a number of solar websites recommend the use of WEEB type grounding jumpers and lugs to electrically bond the Al solar frames to the Al rails and ultimately to a grounding rod…
However, during my research I came across a Youtube video (Solar Panel Aluminum Frame Conductivity / Grounding Issue - YouTube) which suggests that this oxide layer can be ‘breached’ by voltages > 1Kv. Since each panel is fastened by multiple Al clamps to the rails and all the rails are interconnected with a grounding cable/wire and lightning induced voltages are thousands (or more) of volts, then does it make sense to spend money on WEEB grounding accessories? Your expert opinion would be greatly appreciated.
Thanks!
