#solar-inverters #Powerwall #MeritSun #LithiumBattery
Share PROJECT: 15KWH Powerwall Battery With 8KW megarevo split- phase inverter.
Compared with 3pcs 5kwh batteries, a 15kwh battery saves space and is easier to install.
The use of a single 15KWH battery saves space compared to using three separate 5KWH batteries. This is beneficial for installations with limited space, as it reduces the overall footprint of the energy storage system.
