We are considering power needs for intermittent use of an 8mx 10m farm shed and for irrigation for a small orchard and watering stock (near Ballarat Victoria). We envisage using the shed once a week during the summer, sometimes staying over while working on the block. There is no house on the property. Cooking and hot water will be by means of gas and/or wood stove.
One option is to connect to the grid – we have a quote from Powercor and an estimate from an electrician to run power to the shed and provide a meterbox etc. total c $25k.
We could install a small off-grid system to cover all our power needs. We have developed a basic (Clean Energy) spreadsheet for our estimated power needs. It’s a bit hard to do this for intermittent use, but we estimate 3.89 KWh per day average – for bore pump (at 75m depth), small rainwater pressure pump, lighting, charging phones/laptops, ceiling fan, and possibly a small fridge. The bore does not need to be run at the same times as the pressure pump. We may choose to have a backup generator both to re-charge batteries and to power any larger tools we use. The start up power needed for a bore pump to that depth is an issue.
Or we install a stand alone solar bore system (say $8k including tank) and a separate very small solar off grid system for minimal shed needs – lighting, fans, charging only, and manage without a fridge
Cost estimates from our own research and conversations with off-grid suppliers vary considerably – from $10 - 12k for a basic off the shelf system through $16k to $20k plus. There is also some risk of batteries etc being stolen especially as we are not living on the property.
Would be grateful for any advice/ suggestions - have appreciated the articles on this site #off-grid #farmshed #bore pump
