Use this Off grid / Hybrid inverter www.100up.com.au
When connecting your solar panel to your charge controller, it is advisable to connect first the adapter kit of the panel. Then connect the positive (+) or negative (-) leads of the panel and match them to those of the charge controller. See to it that the panel is well inserted; otherwise, you are likely to experience reverse polarity and a short to the system, which can damage the controllers and panels.
