Hi All, I have a question. How do I check the serial number of LONGi PV module? Would you all show me, please? Thanks.
There should be one showing on one of the corners of your solar panel.
Failing that, if you are in Australia whoever sold you the panels should have a record (or whoever they traded the STCs through). It’s a requirement to record them in order to receive the STC rebate.
Does that help?
Thank you so much Marty. Is there any way to check by serial number of PV module on Manufacture’s websit?
What exactly are you trying to do?
Marty Newkirk
0431158662
The serial number is beside the LONGI PV modules nameplate
To check the serial number of a LONGi PV (photovoltaic) module, you typically need to inspect the module itself. The serial number can be found on a label attached to the back of the module. Here’s a step-by-step guide on how to locate and check the serial number:
Steps to Check the Serial Number of LONGi PV Module
- Access the Module:
Ensure you have safe and secure access to the PV module. If the module is installed on a rooftop, take necessary precautions, such as using appropriate safety gear and ladders. - Locate the Label:
The serial number is usually found on a label affixed to the back of the PV module. This label contains important information about the module, including the serial number, model number, and electrical specifications.
3.Read the Label:
Look for a long alphanumeric code, which is the serial number. The serial number is often prefixed by “SN” or simply listed as “Serial Number.”
4.Alternative Methods:
Manuals and Documentation: Sometimes the serial number is also listed in the product manuals or documentation provided with the purchase of the PV module.
System Monitoring Software: If your PV system includes monitoring software, you may be able to find the serial number of each module in the system’s inventory list.
Example of a Label
Here is a general example of what the label might look like:
java
Copy code
LONGi Solar
Model: LR6-60-HPH-xxxM
Serial Number: SN1234567890
Max Power (Pmax): 330W
Voltage at Pmax (Vmp): 33.5V
Current at Pmax (Imp): 9.85A
Open Circuit Voltage (Voc): 40.2V
Short Circuit Current (Isc): 10.35A
Tips for Locating the Serial Number
Clean the Label: If the label is dirty or faded, gently clean it to ensure the serial number is legible.
Take a Photo: For convenience and future reference, take a clear photo of the label showing the serial number.
Consult the Installer: If you have difficulty locating or reading the serial number, consult your installer or the company that provided the PV modules.
Checking the serial number of a LONGi PV module involves inspecting the label on the back of the module. Ensure safe access to the module, locate the label, and read the serial number. If you encounter any difficulties, refer to the module’s documentation or contact the installer for assistance. This serial number is crucial for warranty claims, system monitoring, and technical support.
You can easily find the serial number of a LONGi PV module on the label at the back of the panel. LONGi prints a barcode and alphanumeric code that represents the serial number – it’s usually located near the electrical junction box. The same serial number is also laser-etched on the glass (front side, usually near the frame edge) so that it remains visible even if the back label gets damaged or removed.
If you’re verifying authenticity or warranty, you can scan the barcode or enter the serial number on LONGi’s official website or through their service portal. Each serial number is unique and contains information about the production line, manufacturing date, and product type.
So in short:
Check the back-sheet label (with barcode and text).
Look at the edge of the front glass for the laser-etched number.
Use the serial number for warranty registration or product verification.
This way, you can confirm whether your module is genuine and traceable.
