ZJ Beny EV charger review
Does the OCPP model support working with both the OCPP server and the phone application simultaneously?
It seems you generally had a good experience with the ZJ Beny EV charger, given its great value at $675, which comes with the CT clamp and the DLB box for load balancing. The charger appears to be sturdy and functional, although it is somewhat annoying that the solar-only charging capability means that you need a different Solar DLB box, since the standard one is non-directional. It’s good that the charger is sleek once mounted, but the paper-thin plastic front plate could be a minor drawback as far as sturdiness goes. Hopefully, when you receive the solar DLB unit, charging will be even more hassle-free.
