Should I get batteries with my solar?
If you are planning to pair your battery with your solar power system then you can consume the generated energy for a whole day or more than a day.
If you are living in an area where plenty of sunlight is incident on your solar rooftop system then adding solar batteries is of course the right decision as it will store the excess of energy generated by the system.
As mentioned in the above post an experienced installer will easily fix these batteries with your system.
