Hello, wanting to know if there is a significant difference between panels that have an efficiency of 20.7% and 20.5%
the two panels are described here.
cheers and thanks for the help
Very little difference. Both panel datasheets are the same, the only difference is one is slightly newer and lists a panel with 5W more power. (But you may not actually be able to get that model)
If you are getting the 370W panel, they are both exactly the same.
You need to look into the performance warranty! This is the loss of output over time. Honey claims production of 84.8% after 25 years. The Trina is less at 83.1%.
