Hi i’m looking to design a solar power plant in the middle of a lake around Stockholm’s area.
Can you recommend some panels with corrosive standard protection?
Solar panels have anti corrosion ratings from 1 - 5. 1 being the lowest and 5 the best.
Try this site for side by side panel comparisons. I found it very helpful to make decision on our system next to surf beach
Forgot sit
Use modules that meet the IEC 61701 standard for salt mist resistance. Salt corrosion can also hamper solar inverters, in an area with heavy sea spray, Solar inverter should be placed either inside a cool garage or protected by some form of housing such as a hood or cabinet.
