Hey @Marty, I use two main Brands which are centered around quality and efficiency. Stiebel Eltron which is an all in one unit and very efficient, and SANDEN which is a tank with separate heat pump, and also very efficient and handy if you need to locate the tank separate to the Heat Pump unit.
