Hi, I have a 12kw Growatt DVM Split Phase inverter. Since first connected it has periodically showed a “Fan Lock” fault and shuts down momentarily. After that it started to show “Low Battery”, didn’t automatically switch back to utility and shut down for that reason and I would have to manually switch my transfer switch bypass to “Utility” to bypass it till solar power was enough to charge the batteries. Growatt said to install new software. Before I was able to do that it started flashing the output on and off for a few seconds and then work OK. I installed the new software and when I restarted the inverter, it was OK when connecting the battery and first turning it on, OK when utility was connected, then when the load was switched back on it started flashing on and off the output with the red light, no error codes so I shut it off and did another restart, now it has no output. I’ve tried reinstalling the software and restarting the inverter again but still no output. Growatt says to send it back to the distributor. That’s not realistic for me since there are no distributors here in PH, the closest is China where I bought it. Any suggestions??? Thanks the dog
Related topics
Topic | Replies | Views | Activity | |
2 Growatt 12DVM US version dead | 0 | 17 | June 30, 2025 | |
Growatt 8kw grid tie inverter stays on standby? | 6 | 3221 | October 22, 2023 | |
Inverter shutting down in summer | Grid voltage rise | 19 | 7864 | January 3, 2021 | |
Secondary Slave Inverter for non essential loads? | 2 | 607 | April 20, 2022 | |
Must 1800, 4000 watt single phase, no battery voltage? | 3 | 386 | February 21, 2022 |
