Solar panel tilt angle - Best Roof Pitch
Depends what latitude you reside in the world. You can look up your ideal azimuth angle on-line for different times of the year. But in reality you will stick with your roof pitch angles. If there is concern, you could add an extra panel or two to compensate.
