I am planning to put a 10 KW ( Off Grid System ) on my farm land, Energy is required only during the day time.
Does the off-grid system requires reference current ? If yes will it work as We do not have electricity connection at the site.
Can anyone please suggest ?
Hi @sharma
By definition an offgrid system does not have an electricity connection. You do not need a reference current from the grid.
Let us know if you have any other questions. What area are you in?
Hi Sharma,
What is the system running, water pumps? There are some off-grid water pumping systems that can run directly from solar array using DC controllers.
If you are running AC appliances you will need an inverter/charger which generates the reference voltage of 240V 50Hz (and current).
This is explained further here…
