I am using an Eastman ES6KW-HY-P inverter with a Dyness lithium battery, and I am experiencing a problem with the inverter’s behavior in SBU mode during nighttime operation.
At night, the inverter initially runs in a sort of hybrid mode, where the battery supplies the load while the grid remains ready to support.
However, this behavior lasts for only about 10 minutes, after which the inverter automatically switches to battery-only mode, and the grid stops supporting the load.
In case of overload at night, instead of falling back to the grid, the system shuts down completely.
I have already enabled the Overload Bypass function on the inverter.
During the daytime, the hybrid mode works correctly with the same grid connection, so the issue happens only at night when using the battery.
I would like to request a solution that allows the inverter to remain in Hybrid mode at night, instead of
