Spec of Solar Inverter
#1
Hi, can i get a suggestion on the best kind and spec of inverter and batteries to carry a 1.5HP Air-conditioner load.
#3
Hi if you do a simple conversion in google (1.5HP = 1.2kW). To generate 1.2kW under variable weather conditions I would recommend at 3-4kW of solar panels as I’m sure your home will also have other appliances, lights, fridges etc also running. A 3kW inverter would be suitable but depending on your location it might be worth going bigger if you can afford it. Oversizing solar is a common practice due to the low cost of solar panels in Australia and additional subsidies.
#4
Thanks. That was helpful.
Regards.
Chinedu Ebokam
Projects.
chinedu.ebokam@rensource.energy | +2347017579890
7 Abagbon Close off Adeola Odeku, Victoria Island, Lagos.
Excellence || Kindness || Continuous Learning || Integrity+Transparency || Dependability+Discipline || Humility+Swagger || Teamwork
