Solar System Quote
Hello there,
I have been quoted a 13.23 kW system with storage it includes
42 x Longi 315w split
1 x Solax X Hybrid 5 kW inverter, and 1 x Solax X standard 5 kW inverter
6.3 Kw Triple Power Battery with 2 x eps
$16,700.00 after STC’s
I think it sounds pretty good and was just looking for anyone else to comment on this.
Hi @Hugh_Webb
Yeah it seems not bad on the face if it, run of the mill products.
I’d get another couple of quotes though so you can compare.
Sounds a lot to me how long before you start to get your money back.
I’m no expert, but I understand that Longi “Momno” panels are superior to the “split design”.
I have read that the Solax inverters are not considered as reliable as SMA, Fronius or ABB. However, Solax is cheaper; so you take your chances.
Thanks, for that. Hugh
Thanks for the reply.
On revisiting my quote it is the mono perc LR6-60PE 300-320 panels.
Also I know the inverters are cheaper, however this allows me to fit 10 kW of inverters to my 13.23 kW panel array.
Cheers again
