# Micro inverters (Enphase ) Vs Power optimisers (SolarEdge, Tigo)
**URL:** https://forum.cleanenergyreviews.info/t/micro-inverters-enphase-vs-power-optimisers-solaredge-tigo/224
**Category:** Solar Inverters
**Created:** [March 1, 2019, 10:10am UTC](https://forum.cleanenergyreviews.info/t/micro-inverters-enphase-vs-power-optimisers-solaredge-tigo/224 "2019-03-01T10:10:42Z")
**Posts on this page:** 1
**Showing post:** 2
<div class="post-metadata">
### Author: ![Marty](https://forum.cleanenergyreviews.info/user_avatar/forum.cleanenergyreviews.info/marty/32/4032_2.png) [@Marty](https://forum.cleanenergyreviews.info/u/Marty)
#### Post date: [March 3, 2019, 10:50pm UTC](https://forum.cleanenergyreviews.info/t/micro-inverters-enphase-vs-power-optimisers-solaredge-tigo/224/2 "2019-03-03T22:50:42Z")
</div>
UPDATE - Tigo seems to have an advantage over SolarEdge in this heavy shading scenario.
> [@Tigo vs SolarEdge for heavy shading?](https://perform.discoursehosting.net/t/tigo-vs-solaredge-for-heavy-shading/1546/6):
> No, it rarely is straight forward unfortunately, but this is a trickier installation than usual. To be honest, it’s bloody confusing stuff, you would need a SolarEdge guru to guide you through this one. SolarEdge doesn’t seem to supply a clear guide as to when to use these different Optimisers publicly, I’m sure they have detailed training documents about it though. I’ve been reading through MC Electrical’s review of SolarEdge again, and toward the bottom he highlights how difficult it is to …
I believe what he is saying is accurate. I haven’t used optimisers before, but I understand that it is true regarding needing a number of panels to produce power for the inverter to function.
I guess the logic that if you have heavy shading then you should use micros is probably fair also. Although, if your shading is that bad, are you sure you’ll get enough sunlight for solar to be worthwhile? Is the supplier able to give you an idea of the output of the system, and what impact the shade will have?
_[View the full topic](https://forum.cleanenergyreviews.info/t/micro-inverters-enphase-vs-power-optimisers-solaredge-tigo/224)._
